Porting Number - Issues
masonpynt
Hi guys,
Got the same issue as many others where I've ported my number from my old provider (yesterday) and now cannot receive calls or text messages on the old number.
Wondering if someone may be able to DM me the porting team's number so I can give them a call to figure out the issue?  Its become a bit of an issue as I can't login to any of my banking apps because my 2FA is setup on that number.
2 REPLIES 2
masonpynt
Thank you - appreciate it. I'll give them a call and see if we can get the issue sorted.
HI @masonpynt
if you cannot receive inbound calls/text , it could be stuck port
i have sent you the number. Please check your community inbox
