Can't make calls without 1 in front nor call 811
Q2023
Hi @CS_Agent
Can't make calls without 1 in front of the number nor I can call 811. I have restarted my phone, removed the sim card from phone then reinsert the sim car and nothing. Please help!
Q2023
Alberta area code phone number and calling within Alberta. Sent PM.
Thanks.
@Q2023  please call 1-866-408-5465 . for now
and you have a Alberta area code phone number?  I am pretty sure this is something PM can fix, please open ticket with support:
Q2023
In Alberta.
@Q2023   which province you are in ?  If you are in Ontario, which area you are phone number belongs to?  I remember some part of Ontario has problem with dialing special service number like 811.  If you are in Ontario , please call 1-866-797-0007  for now
and putting a 1 in front of the 10 digits number is normal.  Many of us now to get used to this new way of calling.
Meow
Some numbers in some areas require '1' in front of area code. This is normal. If you contact agent (s)he might be able to explain you Why, if they know.
@Q2023  This is normal at least in my case , all my contacts have the 1 in front of the 10 digit number for calling and texting
Adding and since all plans are national calling this won’t charge you extra for long distance and it can’t as PM is pre  paid and you can’t do anything you haven’t payed for so never a surprise bill
