07-26-2022 02:42 PM
Ever since the new update to the website I’ve been trying to pay my phone bill but I’ve lost access to the email registered to my account and I’m unable to get the 6 digit code to verify. Is there a way around this or is it possible to change the email linked to said account? Thanks.
07-26-2022 03:01 PM - edited 07-26-2022 03:01 PM
@Colbywest01 If you need to make a payment urgently, then purchase a voucher sold by most major retailers, gas stations or convenience store, or even online vendor recharge.com who will email the voucher PIN for a fee and dial 611 on your phone to load the funds. That gives you more time to sort out the email issue.
07-26-2022 02:48 PM
@Colbywest01 hi if you can’t get into your account get customer service agent to change your email you can open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
07-26-2022 02:46 PM - edited 07-26-2022 02:47 PM
HI @Colbywest01 technically you can still use the same email address as username to login, you just need to ask to send the 2FA code to your phone /sms
But yes, you should ask PM CS agent to change the email address used ,
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
