08-11-2025 12:36 PM
08-11-2025 12:39 PM
hi @Blissa
you can ask PM support agent to help with that. You can submit ticket by direct message:
08-11-2025 12:38 PM
yes, you need PM to help to remove credit card and cancel as you cannot properly login
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
