08-10-2025 04:03 PM
hey guys i was unable to find my account number. the thing is that registered email when i opened it showing othing is there any other way apart from email to login to my account
08-10-2025 04:12 PM - edited 08-10-2025 04:12 PM
Ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-10-2025 04:10 PM
You can only login using your registered email ID and password.
If you forgot the email you used to setup your account.
Click on the Chat icon and type in Submit a Ticket then Contact for an agent to help you access your account.
