I want to purchase a cell phone plan....
kakado12
been trying for the past 4 hours...going in circles with  usernames and more than appropriate passwords.
I am exhausted but wish to obtain this plan so that I can use my new phone.
please advise....I am asking for help
can someone throw me a crumb?
xxxxxxxxxxxxxx   previous user for number of years... retired and setting up my new plan....hopefully
Edit by Dunkman: removed personal information
@kakado12
You can’t purchase a plan on the PM website. You need to download the PM app on your new phone and subscribe a new plan.
slusagm
Use amother email address to create a new account
If you wish to use the same email address to create new subscription, you will need PM to check
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
kakado12
thanks...
I will look for "the app".
Have no idea of where the arrow within the box is...least of my current problems...but I am concerned
Chalupa_Batman
Have you downloaded the app? That is how you sign up with Public Mobile. The app!
P.S. Click on the arrow within that box you wrote and remove your email address. These are not private forums.
