08-10-2025 04:04 PM
I'm can't dial out but can receive calls
08-10-2025 04:15 PM - edited 08-10-2025 04:15 PM
Try rebooting your phone first by powering off then back on.
If that didn’t work then you need to contact a CS_Agent by dm them to investigate the issue.
08-10-2025 04:10 PM
You have not removed you old sim card yet. Remove it first , or if disable id it is an eSIM
Then reboot and reset network settings
08-10-2025 04:05 PM
How can I try to fix it
