11-08-2022 03:24 PM
First problem - I can't login to the account I just created with Public mobile.
Second request - I ordered my sim card last night. Can a customer service agent pls hold the 15GB plan for $40 promo for me since it's going to take 5-7 business days for my sim card to arrive?
11-08-2022 03:39 PM
@asot101 Phone ahead to make sure they stock the PM SIM as not all of them do and that's a long way to go if they don't have the SIM card.
11-08-2022 03:37 PM
Thanks for your help Outdoorsman
11-08-2022 03:36 PM
Ya, i'm 1.5 hours from the closest store that holds the sim. Thanks for your help dabr!
11-08-2022 03:35 PM
@asot101 ok I see well it won't work without activation of a plan so you will need to wait for your sim card before you activate or have a self serve account
11-08-2022 03:34 PM - edited 11-08-2022 03:38 PM
@asot101 Unfortunately, they won't be able to hold the plan for you. Do you have any Koodo/Telus stores close by? If you do phone ahead and ask if they sell PM SIMs (official stores do) and then pick up the SIM and keep the ordered one as a spare for future referrals.
edit: also I'm assuming the account you created was this Community Account which is separate from the self serve My Account which is needed for activating a new phone account here: https://activate.publicmobile.ca/
11-08-2022 03:32 PM
@Outdoorsman I just went to the PM website and clicked on create account and it somehow worked. I am still waiting for my sim card to arrive
@dabr I am a new customer, I am currently with Fido and ordered the sim card off the PM website last night. I get my sim card in 5-7 business days. Is there a way for a Customer service agent to hold the $40/15GB promo while I wait for my sim card to arrive?
11-08-2022 03:29 PM
@asot101 Did you lose your phone/SIM and hence the order of a new SIM card? Just a little confused since you said you can't login your account, so you already have activated your self serve account?
Then try logging into the account by clearing cache/cookies and using incognito/private mode and once in, you can select Plans/Add-ons from the left side of page and Change My Plan option, then select the correct $40/15GB plan using the arrow to scroll and choose Change at Next Renewal option.
11-08-2022 03:27 PM
@asot101 hi how did you create self serve account if you didn't activate a plan with a sim? maybe that is why you can't get in
