01-12-2024 11:53 AM
01-12-2024 11:56 AM
Is she currently in US?
Did she connect properly to PM's USA partner?
Can you text her?
Did she purchase correct US add-on?
01-12-2024 11:55 AM
HI @SPK
you should be able to call her. To you, it is just a Canadian phone number and no addon required. what error you got?
and she can receive calls without problem? she can make calls?
and you can call others without problem?
01-12-2024 11:55 AM - edited 01-12-2024 11:55 AM
@SPK Is she in the US ?? You back home in Canada ?? If so you will need. U.S. long distance add on to call her . But best to just text her to call you as she has the roaming add on
