01-11-2024 05:34 PM
Hi All, I'm wondering if others have this problem. We have 4 accounts with Public Mobile and very often when I call my daughter the call will not go through on the first try. Then I have to dial again and it goes through. Wondering what the issue might be.
Service
01-12-2024 11:52 AM
I haven't ported my number, but will try refreshing
01-11-2024 11:37 PM
@msteph wrote:Hi All, I'm wondering if others have this problem. We have 4 accounts with Public Mobile and very often when I call my daughter the call will not go through on the first try. Then I have to dial again and it goes through. Wondering what the issue might be.
Years ago I experienced this issue occasionally, and my theory at the time was due to the lack of VoLTE: Most of the time the phone would be registered to the LTE network for data, SMS, MMS, but to make or receive a call, the phone would have to quickly switch back to the 3G HSPA/WCDMA network for the duration of the call. I though it was possible that if that transition didn't complete quick enough, or there wasn't enough capacity or coverage available on the 3G network at that moment, the call would fail.
The workaround at the time was to force the phone to stay on the 3G network all the time, and disable the LTE network option. Even though Public Mobile introduced support for VoLTE in early 2023, there are still many models of phones that are not compatible with it and continue to switch to the 3G network for calls. Maybe your daughter has a phone where this happens, and if so you could see if the phone has an option to force 3G / disable LTE as a troubleshooting option.
01-11-2024 09:23 PM
Hi @msteph
Did you recently port the number or was it always the case?
I have recently ported my number to PM and had a similar issue there was just one particular number that if it tried calling me for some reason it would not go through.
i had reached out to customer support and they told me they did some refresh and to turn off again and try after 10 minutes, and it was all good for me, suggest you reach out
01-11-2024 06:01 PM
Hmm. Did you port her number or just subscribe a new account for her?
01-11-2024 05:55 PM
It's really weird because it only happens with my daughter's number and it's with everyone who calls her
01-11-2024 05:54 PM
I have heard of this a few times. Not sure what causes that. Sorry to hear that. I could only suggest restart phone.
