07-14-2020 03:29 PM - edited 01-05-2022 12:26 PM
On July 4th public Mobile tried to take money from my credit card and I didn't have enough on it, I since then paid it off completely. I have tried to pay using phone, online, removing and tired adding the credit card, now it won't verify my address. How do I fix this problem? Bank checked it on their end, everything is fine. It's like my account is blocked. The credit card company said they didn't even see Public Mobile trying to take payment. These hours of exhausting work to make a phone work isn't worth the 10 -15 savings.
07-14-2020 05:59 PM
@silvanam if you need service right away you can head to an esso for an instant top up to get your services working.
07-14-2020 04:02 PM
@silvanam While you are waiting for the moderators to respond, here's a couple of suggestions:
Voucher locations: https://www.publicmobile.ca/en/on/store-locator
Vouchers on-line: recharge.com , https://www.ding.com , PayPal Mobile Reload & Phone Top Up in Canada | Xoom, a PayPal Service
Instructions to add a voucher from your phone: https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352/highlight/t...
07-14-2020 04:01 PM
Please reach out to a moderator, to make sure your account is, back in service.
07-14-2020 03:47 PM
@silvanam Some tips to try when entering the address:
Hope this helps!
07-14-2020 03:33 PM
@silvanam , multiple payment failures using the same card can get the card locked out. This maybe the case. You will need moderator team assistance to remove the lock. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team. Good luck.
07-14-2020 03:33 PM
@silvanam wrote:On July 4th public Mobile tried to take money from my credit card and I didn't have enough on it, I since then paid it off completely. I have tried to pay using phone, online, removing and tired adding the credit card, now it won't verify my address. How do I fix this problem? Bank checked it on their end, everything is fine. It's like my account is blocked. The credit card company said they didn't even see Public Mobile trying to take payment. These hours of exhausting work to make a phone work isn't worth the 10 -15 savings.
@silvanam When you log into your account do you see the Reactivate button? Click that to push your payment. It's also a good idea to clear your cache/cookies and use a different browser with incognito/private mode enabled. You can also dial 611 and pay using your registered CC on account or a prepaid voucher.
07-14-2020 03:32 PM
@silvanam you may reactivate a suspended account online or by calling 611.
Via your account online
1. If you have already registered, or will first register, a credit card, go to step 2. OR deposit a voucher for at least your plan cost and go to step 3.
2. Go to the payment tab, select single payment and amount due.
3. Select the reactivate account button.
4. Restart your phone.
or Using 611 to make your payment: ( you need your 4 digit pin to buy an add on)
1. press 1 to make payment
2. press 2 credit card ( or 1 voucher)
3. press 1 amount due.
If this fails, your card may be locked from too many attempts Contact the moderators and ask them to apply payment and reactivate your service for you. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
