Can notmake or recieve calls
02-21-2019 03:14 PM - edited 01-05-2022 06:42 AM
outgoing calls to a local number = message says that the call is long distance and can not be completed.
incoming calls go straght to voice mail.
I can receive text messages.
What the heck is going on? Fix please.
Service
02-23-2019 12:04 AM
You might not have a plan that supports incoming/outgoing calls
02-22-2019 10:30 AM
@Flashdance wrote:I figured it out!
The solution is to switch to a provider that provides the service that I PAID FOR, and a provider that actually provides support instead of hobby commentators.
Watch social media for more on that front.
Filing a complaint with the CRTC. and DUMPING this pathetic excuse for a cell service provider asap.
So why do you suppose thousands of people are happily going on with their lives enjoying saving money here with service that just keeps on ticking?
All of this emotion and escalate and crtc for...wait for it .... $10. Or even $8 as the case may be. I get the principle but jeez.
Enjoy spending more at another provider. Maybe you'll be back when you see that you're spending so much more and that you have few to no opportunities to reduce your costs like with the rewards here.
I have a re-used term for this support model...crowd-sourced techsupp. There are bunch of people here very knowledgable about phones and add to that knowledgable about this service. It's what one signs up for here. Less for less.
02-22-2019 09:30 AM
I figured it out!
02-22-2019 08:48 AM
You arent expected to do anything..advice/suggestions is what you get on this forum..sometimes someone else can see something you dont that will resolve an issue..anyways hope you get figured out.
02-22-2019 08:03 AM
@Flashdance wrote:DO you SERIOUSLY expect me to screen cap my usage stats and then spendmy time editing the screen cap so that personal details are obscurred? Do you REALLY think that a paying customer should submit themselves to all that effort?
Nope, that effort is reserved for a formal complaint to the CRTC.
Not kidding either.
Escalate this.
Yes, we seriously expect you to do that as we are all just customers like yourself and you are on a mostly self service provider. Or did you not do any reading about how it works here BEFORE you signed up?
02-21-2019 04:45 PM
Not kidding either.
Escalate this.
02-21-2019 04:42 PM
I have already screen captured my usages stats for Jan 21 to Feb 21. I have used 41 minutes.
This screen cap is needed so that I can inform the CRTC of this as it appears to be a deception..
I PAID FOR 50 minutes and used 41 minutes. I contacted a moderator and have not received a reply. I am CERTAIN that the CRTC will repsond promptly and deal with it.
02-21-2019 04:35 PM
Can you screen shot your account status page? Omit any personal information. That might help us sort things out.
Otherwise, you may need to contact moderator (PM employee) via private messaging, but that takes 1-2 days for response.
Send a private message to moderator through the following link :
You could also try the lost/stolen phone trick:
02-21-2019 04:03 PM
Hmmm....no replies huh?
Maybe the CRTC can help.
02-21-2019 04:00 PM
Account renews tomorrow and I have used 41 minutes over the past 32 days.
02-21-2019 03:58 PM
Accirding to the publicmobiel web portal I have used 41 minutes over the past 32 days. NOT 50.
02-21-2019 03:54 PM
@Flashdance, we are all customers here. You'll need to contact the Moderator_Team via private message if you wish to escalate it.
Please see the Get Help link at the top of every page.
02-21-2019 03:53 PM
So, it seems you've used all of your combined 50 minutes. You will need to add minutes.
02-21-2019 03:53 PM
Escalate please. This is unacceptable
02-21-2019 03:48 PM
1) the $10 plan is for ALL OF CANADA
2) I have called those same numbers regulary for 6 months.Area codes used are NOT long distance.
3) Incoming calls also do not come through. All calls go to voice mail.
02-21-2019 03:43 PM
@Flashdance wrote:I have $10 plan and have used 41 minutes.
Airplane mode is OFF
Ringer volume is up. Calling from 647 area code to 416 and 437 area codes (local calls)
So the calls to 416 and 437 may not be "local" as local calls are not so-called covered by Public Mobile. ITry dialling with a 1 to complete the calls. It should remove the message, as the message is most likely saying 'charges may apply' but they won't.
I'm in a 226 area code, and I can't call without the 1 to other areas off 226 as they are long distance. 519 also, and whatever the new overlay is in South Western Ontario.
If it still doesn't work, try adding long distance minutes (200 or 400 pkg), and if it still fails, contact the moderators to reprovision your account.
02-21-2019 03:38 PM
The Silence is deafening.
Maybe Rogers can help?
02-21-2019 03:28 PM
@Dunkgirl wrote:
@Flashdance wrote:outgoing calls to a local number = message says that the call is long distance and can not be completed.
@Flashdance Did you just port in?
Came to public 6 months ago
Mobile 6 months ago.
02-21-2019 03:27 PM
Outgoing call gives you a long distance message, so not a signal issue. It is probably an account issue. Account did not set up properly?
02-21-2019 03:25 PM
02-21-2019 03:25 PM
02-21-2019 03:21 PM
By chance, do you have the $10 plan, 50 minutes (incoming and outgoing) and 50 texts (outgoing) plan. If you do have this plan, you may have ran out of minutes.
02-21-2019 03:21 PM
@Flashdance, what plan are you on, please be specific.
Where are you calling from, where are you calling too?
Have you just signed up? Have you checked that Do Not Disturb is off, Airplane mode?
