can't receive calls and texts
Stanislaw24
I started a subscription on February the 15th. I can not recieve calls or texts messages from others and can not login into my account.
2 REPLIES 2
@slusagm wrote:
  did you reply Yes to your old provider's porting authorization text?
there is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
It hasn't yet been established that there is a number porting issue or even if the customer has even requested a number port.  This is partially the reason that Public Mobile has discouraged the discusson of such porting department phone number.
slusagm
