calls
VC77
Hi Community
I cannot  make calls or send texts.  I CAN recieve calls.
REcently ported from Bell on eSIM.
I have powered off/on...switch airplace mode off/on...checke esim and it matches whats on the phone.
Im unsure what else to do
Can someone provice a link to enter a service ticket? Can't seem to do that either
Thanks
1 REPLY 1
slusagm
can you check if your Bell esim is disabled?  check it on your phone, go to Sim Manager page
and make sure the Public Mobile sim is set as Primary and enabled
if you need PM to help, you can open ticket by message
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
