10-17-2026 04:19 PM
10-17-2026 04:59 PM
Just wondering what is the make and model of your phone?
With the 3G shutdown in March 1/27. You will need VoLTE to make and receive calls.
Here is more information on VoLTE so enter the IMEI of your phone to see if it is VoLTE compatible on PM network:
10-17-2026 04:30 PM
did you just join PM and requested porting your number into PM ?
If you are porting your number, did you reply a text to your old provider and reply YES within 90 mins? If you miss that, the porting was not completed and hence you are not receiving incoming calls. There is a number you can call to talk to live support and re-trigger the process. I will message you the number, please check your Community inbox, envelope icon on top right
if you are not new to PM, incoming calls and text were working fine before and just not working now, try to :
