Thursday
I can't receive any calls or texts but I can call out. I have tried every step possible and I am about to go back to Freedom if it doesn't get resolved by the end of day
Thursday - last edited Thursday
Check to see if your phone is VoLTE compatible on the PM network. You need VoLTE to make and receive calls after the 3G shutdown coming up.
Here is more information on VoLTE and enter the IMEI of your phone:
https://www.publicmobile.ca/en/get-help/articles/volte
If it is compatible then reset the network setting on your phone.
Thursday
I got your message saying Freedom said the number was ported, but PM said not. I think @porcupine had similar issue earlier, maybe porcupine can share the experience? thanks
Thursday
Freedom is the worst for porting out numbers get an agent to help you it took me 3 days too port out
Thursday
no need to go back.
you just ported your number here? if so, it could be a porting isue
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please open ticket using Public Mobile Expert Messaging , Select Start a Chat to begin (You will need to use your current Community account to login to submit the ticket):
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/sms alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
