Can i switch to the new plan of 30/30 with 1gb data
03-30-2018 06:07 AM - edited 01-04-2022 03:48 PM
03-30-2018 01:54 PM
@daviddwhwrote:This way I'm basically a new member of the pm?
That would be correct.
03-30-2018 01:52 PM
03-30-2018 09:18 AM
If you don't care to keep your phone number, you could also just get a SIM and activate it on the $30 plan, and cancel your existing account.
03-30-2018 08:43 AM
@twest666wrote:Sorry you will have to starts a new account.
You could probably get it but it will take a bit of work and a small amount of money.
First, you would need to get a PM SIM and activate it with the plan and a new number.
Second, pick up a bell prepaid SIM and use it to port out your PM # from the 500 Mb plan. Cost would only be a SIM as no balance is required to port in a number. Plus whatever time you have paid for on PM.
Third, port number from bell SIM that you just ported from PM into the new account with the 1 GB plan.
Not sure if you will think it's worth the work.
+1. Chatr is offering free service for a month right now. Porting to Chatr and back could save the cost, but not the hassle.
03-30-2018 07:44 AM
