app not working
BobAllen
my data on my phone is not working and I can't open the Public app
2 REPLIES 2
Sansan
@BobAllen  do you have an android phone? Check your APN settings.
Open your phone’s settings and tap:
Access Point Names
New APN settings
Verify the following field match:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
slusagm
Reboot your phone first and try again
check if you have any limit enable with mobile data.  Many phone has such settings and blocked mobile data
since you can post here, you can use Wifi to connect to My Account using the browser.  Access My Account https://myaccount.publicmobile.ca and check if you have used up the data
