a month ago
Hello,
I ported my number from Fizz and received confirmation from Fizz right away confirming the number transfer.
Hours later, my data is working fine but I'm unable to make calls/send texts. I've reset network settings and restarted my phone and done all the troubleshooting, but to no avail.
Help!
Duggie
a month ago
Sometimes there is a delay for each of data, calls and texting to work. Hopefully it should resolve itself.
If after waiting and trying reset/restart not working, you will need to contact a customer agent:
BTW, What phone are you using? If it is not volte compatible, your calling will not work and you may have to buy a compatible phone unless you can find some way to enable it.
a month ago
@hairbag1 thank you for responding! I replied YES to Fizz and they sent a text saying "Ok. We'll inform the other service provider that you confirmed the transfer." I'm using an e-sim and not a physical card, so wondering if that's the problem.
Fizz immediately deactivated my data and calling, so it's all done on their side.
a month ago
so you replied YES to the sms sent from Fizz ? If so, try removing old sim and install Public Mobile sim...see if that helps.
