US roaming add on doesn't show in my account
03-30-2018 01:54 PM - edited 01-04-2022 03:48 PM
I purchased the 15 dollar us add-on 5 hours ago, I did the 2 steps, add fund then puchase add on. It showed me it's done right after I clicked confirm button.
But until now my account is still showing no add on plan has been purchased.
Can any one take a look at it please.
My phone number is 647 xxxxxxx.
03-30-2018 02:41 PM
Sometimes there is glitch, the fund is in your account, but didnt purchase the addon for you. If this is the case buy it again.
03-30-2018 01:59 PM
@yingw513 I would suggest removing you number as this a public forum and any bot could pull your number from the post.
Second do you see it in your transaction history that the amount was paid for the add-on?
If you see the amount is taken for the add-on, you will need to contact a moderator, if not try buying the add-on again.
Use this link to send a private message to the @Moderator_Team, include all relevant information in your message, such as account number, PIN, phone number, and your situation.
03-30-2018 01:58 PM
@yingw513 Do not post any personal info here as this is a public community.
Do you not see the add-on on the Plan Detail page? If not, You will need to send a private message to the Moderator_Team with your account info.
03-30-2018
01:58 PM
03-30-2018
01:59 PM
NDesai
My phone number is 647 xxxxxxxx.
