03-07-2025 08:15 AM
Hi, my subscription updates today, I was trying to use my rewards to add US roaming on and it says your account has been suspended make a payment to reactivate, but I did make a payment as I’m set up for auto pay
03-07-2025 09:17 AM
check with PM CS agent and they can investigate further
please open ticket with PM support:
03-07-2025 08:53 AM
My bank shows the money was taken out, my phone works fine its just can’t use the rewards for some reason
03-07-2025 08:25 AM
Latley the autopay feature for alot of people have being failing for many people. Did you verify that the autopay actually went through? Check your bank.
If it didn't, you'd need to many make a payment first to resume service in order to continue with the add-on. Is your phone working? Can you make outgoing calls?
You can also call *611 to make a manual payment with the cc on file.
03-07-2025 08:22 AM
login My Account using browser with Incognito mode to confirm if account is active. Check Payment History page ( https://myaccount.publicmobile.ca/en/account/payment/payment-history ) to see if it records the renewal
then when still in Incognito mode, try to redeems points for the US addon again on the Rewards portal
