Can I use my phone?
bwh0802
My phone is galaxy note 20 ultra(N986N) but  didn't find it on the list of phone type to choose.
it is a 5G model but I have been using LTE until now. can I use your company?
@bwh0802
It should work with new phones (since I see that all carriers offer this phone in Canada).
PM calls are operated on 3G so you might have to change your cellular settings.
HI @bwh0802  N986N is a Korean model, but it will work in PM
Meow
Samsung phones should definitely work with PM. S7 works perfectly and I do not see a reason why newer phones should not work.
Ideally! if you can test it with PM SIM to be 110% sure.
Dunkman
@bwh0802
Public mobile phone compatibility list is not updated frequently.
That model phone will work on PM Network.
Here the specs of the phone:
https://www.gsmarena.com/samsung_galaxy_note20_ultra_5g-10261.php
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
3G = 850 (5), 1900 (2)
4G = 850 (5), 1900 (2), 700 (12/13/17/29), 1700/2100 (4), 2600 (7), 1700/2100 (66)
Jb456
@bwh0802 Yes it will work on a Public Mobile
