03-08-2024 10:07 AM - edited 03-08-2024 10:07 AM
What the title says. Can I buy an add on or something to get my phone to work in south america?
03-08-2024 11:25 AM
Hey Channah,
I have actually traveled to South Africa and you will need to have an unlocked device and buy a local Sim card, it won't work on the public mobile network.
03-08-2024 10:56 AM
nope. Your PM service only works in Canada or US with correct plan / add-on. Airlo.com has a select of travel plans available. My friends use them and are happy with that product.
03-08-2024 10:51 AM
Check out Airalo or Ubigi for esim data plan options. Assuming your phone is esim capable, otherwise you can look for a physical sim card when you get to your destination.
03-08-2024 10:11 AM
@Channah No sorry PM only has roaming in the US . You would. E best served to buy local pre paid SIM card in your destination for your trip away
