Can I transfer my cell phone number from 7eleven to Public mobile
04-18-2023 04:45 PM
I want to keep my same cell number. I want to transfer from 7eleven to Public Mobile
Joining Public
04-18-2023 07:29 PM
@EvS2022 100% you can port from 7-11 SpeakOut to PM, I did it without requiring any intervention from support. Refer to this post, Success Porting from 7-11 Speakout to PM - Community (publicmobile.ca)
This is what worked for me, hope it helps you!
04-18-2023 07:20 PM - edited 04-18-2023 07:21 PM
Keep your 7-11 SIM in your phone and activate the PM SIM then reply to the text from 7-11 with YES to confirm you are porting your number over to PM…there is a 90 minute window for you to reply or porting will be cancelled.
Once you confirmed, the 7-11 SIM will continue to work until porting is completed.
04-18-2023 04:50 PM
likely yes.
first check if you number can be ported into apm first, check here
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
and, porting experience from another customer you might want to check
04-18-2023 04:48 PM
