04-18-2023 06:30 PM
I accidentally purchased a US Roaming (talk and text), as well as a US Roaming (talk, text, and data). Can I remove the original talk and text I purchased and get my $ back?
04-18-2023 06:57 PM
Not a problem.
Contact agent, explain what you did and hope they will refund you.
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
04-18-2023 06:38 PM
Only support can remove and credit your account for that.
Click on the chatbot (simon) link down below and start a chat and find your way to submit a ticket. Use the pin option to verify after you log in with your community account.
