US /Canada coverage
HH53
What is least expensive plan and/or addon so when travelling to US from Canada I can call back to Canada with no long distance or roaming charges?
funpig1
It all depends on how much data you need per month and how often you travel to the US.  If you only go down a few times in a year or only use about 5GB per month, the $36 plan is a big waste of money. And once you sign for an expensive plan, it is very difficult to downgrade to a cheaper one. Only buy what you can reasonably use.
FWIW, you could call Canada for free uf you use an app like TextNow. You get a free VOIP number to call anywhere to and from the US and Canada. I even used it in Japan to call back to Canada toll-free. I can even call forward my public mobile number to the TextNow number so that people can just phone my PM number and the call will be call forwarded to my TextNow number anywhere in the world.
You just need free wifi. Or you can buy a mobile data esim.
Chalupa_Batman
What you see below or above in the other post is called an Addon. It's not a plan. Here are all the plans with Public Mobile. Best option right now is $36 60GB Canada US Mex
https://www.publicmobile.ca/en/plans
slusagm
Cheapest for able to call back Canada in US is to buy a Talk / Text roaming add-on for 15 days for $15, that is on top of your current plan.  If you don't have a plan yet, cheapest is to get the $19 plan
And you need to make sure your phone is on OM's VoLTE whitelist  for voice calls to work in US
https://www.publicmobile.ca/en/on/get-help/articles/volte
