07-04-2025
08:14 PM
07-05-2025
12:23 AM
computergeek541
My data hasn't been working since I switched over from Rogers. I tried everything help
edited by computergeek541: corrected the catgegory label (discussion is unrelated to issues about how to use the Commuinity website)
07-04-2025 11:07 PM
@CindyTonon wrote:My data hasn't been working since I switched over from Rogers. I tried everything help
It's probably that you need to change the APN setings to the ones provided here, but if that doesn't work, it's gonig to be a service provisioning issue. Provisioining issues would need to be look at by a CSA.
07-04-2025 11:06 PM
@slusagm wrote:What phone is that? It could be an incompatibility issue. Tell us the phone model and we can check
But try Reset Network Settings. It is usually good to do that when you switch provider
It's not a compatibility issue if calls and text messaging work. Data works on any available Public Mobile network type.
07-04-2025 09:56 PM
07-04-2025 08:20 PM
Make sure your phone's data is turned on. Also, because you were on Rogers, I'd suggest going into your Settings and clear your network settings and reboot.
Did you get the text from Rogers requesting porting? Did you say yes within 90 minutes?
