02-13-2026
04:16 PM
02-13-2026
04:19 PM
computergeek541
I bought a US Roaming - Talk Text (15-day) add on to call a number in the 704 area code in the US from Canada but I keep getting an automated message saying I am out of minutes.
Did I buy the wrong addon? Can I get a refund if I did? Which is the right addon?
02-21-2026 08:31 AM
Thank you very much that was exactly what I needed
02-13-2026 04:18 PM
hi @Anakin
you bought the wrong addon. Calling into US from Canada just need the 1000 US Calling LD minutes, not the roaming. Roaming is when you are in US
so, ask PM agent to help to reverse the purchase, and you can then buy the correct addon after
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
