2 weeks ago - last edited 2 weeks ago by computergeek541
Just became a customer, tried carrying over my old number but it never worked. I can't do anything in the app or account settings since it needs a code that's sent to the old number. Which can't get any texts or anything! Doesn't help you have no actual support that you can call or the like.
2 weeks ago
You have to contact your old provider and they will transfer your number. That's what I did and they had no problem doing it.
2 weeks ago
Send the message because they might take a while to get back to you anyway, and hopefully when you wake up tomorrow they will have gotten touch with you. Provide as much information as you can. Your email, the phone number. Name. Whatever you use to sign up so that they can identify you and reduce the back and forthtime.
2 weeks ago
It's a sound idea (waiting that is!) I'm just very frustrated. I can't do anything at all with my number at this moment. I didn't realize there was no phone support. I'd just like to close this account and start with a new number so I'm not double dipping at payment time.
2 weeks ago
I just get stuck in the perpetual loop of e-mail codes, which then leads me to the text code to verify. I've almost had enough for the night. Thanks all for the help! I'll pickup tomorrow and hopefully get this resolved.
2 weeks ago
Not a good idea. I know it's frustrating but give it a few days. I heard you will be banned from using cc in the future for 12 months. Can't confirm personally. Give pm a chance to fix it.
2 weeks ago
That should bring up email option I think
2 weeks ago
There is but I can't get anything text or sms since the number porting failed.
2 weeks ago
Is there resend code try that if there is
2 weeks ago
Sounds like a plan! I'm almost tempted to just waltz into my bank and issue a stop payment if it can't be resolved.
2 weeks ago
I think because the account cannot be verified yet, you won't have that email option. So proceed to follow at @softech suggestion and send a private message.
2 weeks ago
All I get to is the "Confirm your identity" landing page that's trying to get the code to the number I can't get. I see no box on the page to select e-mail the code.
2 weeks ago
There should be a drop box tap on send by text then if remember right it’ll show by email
2 weeks ago
I'm not seeing it.
2 weeks ago
No sim was available lost the phone, got a pixel and downloaded an e-sim. Maybe I'm out of touch with these new phones. Service is still active on the other phone. Other words sounds like I'm out of luck.
2 weeks ago
Open app again try to log in…when send code comes up there is option to send by email.
2 weeks ago
I'm still locked out of my actual account though. I can use the chat since it gathers my token from here but anything account related needs the 2fa code which I can't access due to the failed number transfer. E-mail a code isn't an option since it garners the same result, I need the 2fa code to verify the account. Which again can't receive the code!
2 weeks ago
Did you take the old sim card out of the phone? You need to leave it in until you get all the conformation text. Also it still needs to be active with your old provider. The online instructions will tell you when it is time to swap the cards.
2 weeks ago
is the account with you old provider active?? it has to be active for the number to port
but discuss with support and see if they can help to complete the port, or help to close the account if you want . Please submit ticket by direct message
2 weeks ago
@KerryC wrote:Just became a customer, tried carrying over my old number but it never worked. I can't do anything in the app or account settings since it needs a code that's sent to the old number. Which can't get any texts or anything! Doesn't help you have no actual support that you can call or the like.
A ticket can be opened using the chatbot to contact a customer support agent. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
