Calls
Reps
I just registered to PM last night and now can’t make calls. Is it because of eSIM card? How does it work? What am I supposed to do?
No, that's factory reset. The network reset will remove all your saved wifi's and bluetooth pairings.
Reps
By Resetting, won’t I clear everything on my phone? 😳
@Reps check if you installed the eSIm profile successfully and if the eSIM is set active.
If you have another eSIM from another provider, disable it.
If you still have a physical sim from another provider, pull it out
And if you confirmed your PM eSIM is installed, try clicking Reset All Networks and see if it helps
Dunkman
@Reps
Is anything else working?  Data? Text?  What about incoming calls? Was your credit card charged? Did you get a welcome email from Public mobile?
Maybe try to reboot phone.
If that does not work, try a network reset of phone (this will erase saved Wifi settings).
