Calls not being completed
OTMTheatre
Hello,
My phone number is xxx-xxx-xxxx. When I try to make a local phone call I immediately hear a message that says "sorry, we cannot complete your call. You do not have an active long distance add-on..."
Can you help me sort this out? I have not been able to make phone calls for 2 days and when I look at my account online everything appears to be good.
edited  by computergeek541: personal information removed
geopublic
@OTMTheatre  Did you just get back from a trip? Instead of using your conatcts to make a call try calling the number directly with a +1 in front of it. Does the call go through? If yes, then you need to fix the settings in your contacts.
hycm53
@OTMTheatre wrote:
Hello,
Thank you
Adam
Try dial 1 before xxx-xxx-xxxx.
hairbag1
@OTMTheatre wrote:
Hello,
Thank you
Adam
Sounds like you have the $10 or $15 plan with limited calling and you've hit your limit. Log into my Account and see if you have any minutes still available to you...if you see none, that means you've run out until renewal. An option is to get the $5 / 500 minutes of Canada wide calling.  The beauty with that is those minutes don't expire (long as your plan stays active) until you've used them up...even if it takes 2 years to go so.
Good luck.
Triguy
You should delete your phone# by clicking on the 3 dots.  Try putting a 1 infront of the area code.
ChuckYeah
It's best if you remove your phone number from your post. You can Edit it by using the three dots at the top right of your post.
What plan are you on? Any chance you've used your minutes?
