07-08-2021 11:41 AM - edited 01-06-2022 02:44 AM
I recently had to do this & found the process a bit of a nuisance & way too expensive. Spending $15 for a whole bunch of minutes when I just wanted to make a 5/10 minute call really didn't fit my needs.
I'm sure there are lots of users that need to make this sort of call once in a while..an impulse purchase, family emergency etc., etc.
How about a fixed rate (ideally low) for this sort of situation. You could have a monthly time limit if that makes the idea more appealing.
Cheers.
07-08-2021 12:12 PM
@lpletzer wrote:I recently had to do this & found the process a bit of a nuisance & way too expensive. Spending $15 for a whole bunch of minutes when I just wanted to make a 5/10 minute call really didn't fit my needs.
Cheers.
This addon will stay on your account for as long as it takes to use them up.
Sure, it may take a while; but they do not expire until all the minutes are consumed.
07-08-2021 11:56 AM - edited 07-08-2021 11:58 AM
@lpletzer...download the free TextNow app to place free calls and texts to/from US. Works good using your wifi. Did I mention it's free !!
07-08-2021 11:49 AM
.. it would be nice if we can buy smaller block, like $5 for 200 mins.
However, looking at PM Long Distance addon, they are all $15 block. I guess they want to make some money as well as easy management -- not too many options.
07-08-2021 11:46 AM
I doubt that would happen as PM is prepaid. It would be more administrative work for PM being a second tier provider would be cost prohibitive.
07-08-2021 11:45 AM - edited 07-08-2021 11:46 AM
@lpletzer yes, it's $15 for USA LD calling minutes.
If it is just USA, maybe there are couple workaround.
1. you can buy Long Distance calling cards and I think they have $5 card.
2. you can try App calling. TextNow is free to install and free to call Canada and USA. You register and you will pick a local number. Then you can make long distance calls to USA for free.
Yes, they are not be most convenient solutions, but they are either cheaper or free .
