07-02-2026 02:41 PM
I cannot make outgoing calls to 1-800 phone numbers and I need this service asap
07-02-2026 03:00 PM - edited 07-02-2026 03:01 PM
@Smiley1961 wrote:I cannot make outgoing calls to 1-800 phone numbers and I need this service asap
It could take some time for Public Mobile to get back to you via chat and resolve this matter as it has to be completed on their end. I would highly recommend downloading a VOIP app like Fongo which is free as a temporary solution to call 800 numbers until this problem is solved.
07-02-2026 02:41 PM
hi @Smiley1961
it can be fixed quickly. PM support agent will refresh the account and it will be fixed
submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
07-02-2026 02:39 PM
I cannot make out going calls to 1-800 phone numbers
