02-22-2024 11:01 AM
Hello i have a subscription it says unlimited calling and text minutes in Canada. When i tried today to call out it says yo ur call cannot be completed you need to dial 611 or something yo buy more minutes?
how to get my calling working?
02-22-2024 11:59 AM
@Holubmd wrote:Oh brother im am so sorry for all the hassles i realized the number was short one digit. And was the reason. 1 was not the missing one it was a 0 at the end of the number. All good now. Thanks so much everyone. My bad
02-22-2024 11:47 AM
02-22-2024 11:35 AM - edited 02-22-2024 11:40 AM
@Holubmd wrote:When i did that it says your call cannot be completed as dialed
try 1 more time without the 1 then !
added...you are trying to call a Cdn number while you're in Canada...right ?? To call different country, you need an international addon for some countries.
02-22-2024 11:34 AM
02-22-2024 11:33 AM
@Holubmd tried on data and wifi no difference
Are you saying that you have data or is that not working either? (Wifi has nothing to do with Public Mobile).
02-22-2024 11:29 AM
@Holubmd check
Outage map in your area:
https://istheservicedowncanada.com/
if no outage maybe submit ticket with support to investigate for you
send a private message To CS_Agents
02-22-2024 11:29 AM
have you tried adding 1 ahead of area code...see if that helps and let me know.
02-22-2024 11:22 AM
I have esim
02-22-2024 11:21 AM
@Holubmd wrote:I have tried restarting phone tried on data and wifi no difference
if you have a hard sim in your phone, try it in a different cell to see if that helps or same results. (IF esim this won't be possible)
02-22-2024 11:13 AM
02-22-2024 11:12 AM
Hello
I have 75 gb plan i think is 50 $ month has unlimited calls and text in canada
02-22-2024 11:08 AM
@Holubmd - If you have the $15 plan with 100 minutes or are calling internationally then you would need to buy add ons via 611 or in your self serve account, here is how to do it.
1.Press Subscriptions & Add Ons
2. Scroll down, then press 'Shop Add ons'
3. Chose an add on for Canada calling.
02-22-2024 11:03 AM
ignore that message if you have something greater than the $15 plan. Try restarting the phone and dial again. Try later or in a different location...could be just a local network interuption.
