Callers receive 1B1 notifications
12-18-2024 01:12 PM
12-21-2024 10:50 AM
Call forward is off. For a brief time Thursday I got through and picked up my voicemail and it would accept incoming calls. Now today it’s back to 1B1 error messages again.
12-21-2024 10:50 AM
Call forward is off. For a brief time Thursday I got through and picked up my voicemail and it would accept incoming calls. Now today it’s back to 1B1 error messages again. We did open a ticket and they reset the password but am not sure what else was done.
12-18-2024 04:03 PM
I have an eSIM. Therefore cannot transfer it to another device to test. I’m in the US and the only call I’m making is from another service that I use while I’m here. I do not use roaming
12-18-2024 01:54 PM
the 1B1 code may be related to call forwarding, check your settings to make sure its not on.
assuming your plan is active and paid up to date. If this doesnt fix it, i would try using your sim in another device to narrow down if its a service issue or device issue next.
12-18-2024 01:22 PM
do you have call forwarding turned on? 1B1 can be related with call forward error
12-18-2024 01:15 PM
hi @kenellis
can you make outbound calls youself ? data work? just want to make sure if your plan is active , any chance the autoapy failed and account is suspended
if account is active, try reboot the phone first
if same, submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
