10-03-2019 12:11 PM - edited 01-05-2022 07:23 AM
So I just signed up for the $25 plan here at Public Mobile and I thought I would at least know what the phone number calling me would be but, when I do get a call it just shows the number 999-999-9999, is this normal or is there something wrong?
06-03-2021 05:18 PM - edited 06-03-2021 05:20 PM
For call display issue, if someone who called you, and his number is on your contact or on your SIM, is it not showing at all? saying private number?
did you try from different phone numbers and if you get same result?
06-03-2021 05:15 PM
you try to import contact from phone to SIM? Only phone numbers and names will be transferred to SIM, this can follow this if it is an Samsung, other Android would be similar:
06-03-2021 05:11 PM
Yes, how do I import contacts to my SIM? My caller display also isn’t working.
10-03-2019 09:13 PM
Check your call usage on your account. What numbers are calling you?
10-03-2019 09:00 PM
it still should display the number. Did you try restarting your phone as this sounds very odd to my for this display?
10-03-2019 08:59 PM
I tried it with a different phone but now it just says: No Caller ID, and it is from a number I saved in my contacts.
10-03-2019 08:58 PM - edited 10-03-2019 08:59 PM
@Ninja0628 wrote:Try importing your contacts into the SIM.
How do I do that?
10-03-2019 01:53 PM
10-03-2019 12:22 PM - edited 10-03-2019 12:22 PM
@JP2997 wrote:So I just signed up for the $25 plan here at Public Mobile and I thought I would at least know what the phone number calling me would be but, when I do get a call it just shows the number 999-999-9999, is this normal or is there something wrong?
No name display at Public Mobile. The number's all 9's? Is it all calls?
10-03-2019 12:14 PM - edited 10-03-2019 12:22 PM
It could be from the person calling you. Can you see the number from other calls ? If you have another phone maybe try calling your cell# to see if it is displayed.
