Call works, No Data, no Texting
Cat2024
Ported phone with eSIM for 3 days. Only call works, cannot send text message but able to receive. In settings I have a primary eSIM but when I pull down the shortcut tab it showing “No Sim”.
I have iPhone13, tried to restart network and the phone. Also tried to edit the APN from isp.mb.com to sp.mb.com per instructions. However not seeing option to check MMS or proxy. Help!!
Cat2024
Submitted a ticket, still pending resolution.
fixin1
@Neil11 - They just recently fixed the issue, but now it will take 1 hour or so for SMS or MMS to properly start up.
[Solved] Text Message Issues for Recently Ported Numbers
Neil11
Ongoing issue for new activations. PM is working on a fix.
You will need to contact customer service agent to fix your issue.  Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
@Cat2024
check your APN settings (iPhone Only):
Open your phone’s settings and tap Cellular > Cellular Data Network
Verify the following field match:
APN: SP.MB.COM
You might also want to Reset Network Settings on your iPhone
