01-31-2025 11:52 AM
Call ends automatically both incoming and outgoing. What to do ?
01-31-2025 12:34 PM
Thank you, it worked, I rebooted and it's working now. Thank you !
01-31-2025 12:11 PM
01-31-2025 12:03 PM
@Wei1155 CS_Agent very rarely contribute or answer here in the community where only customers are, so you'll need to click on the link below to reach a support agent and then keep an eye out on your community inbox.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
01-31-2025 11:59 AM - edited 01-31-2025 12:00 PM
@Wei1155 Are you currently in Canada? New customer or existing? Is your phone set to connect on 3G, 4G/LTE or 5G? Do data and texting work? How quickly do the calls disconnect, is it during a call or does the call never connect? Also check the outage map here
01-31-2025 11:55 AM
Try rebooting your phone by powering off then back on.
If that didn’t work, go to setting and Reset Network setting.
If both didn’t work then you need to contact a CS_Agent to investigate.
01-31-2025 11:55 AM
@CS_Agent what should I do. Thank you
