06-21-2023
08:46 PM
06-22-2023
02:57 AM
computergeek541
I’ve been billed 5 times which is mad I can’t pay rent now and there’s no history legit enough to provide the bank and bank says you guys got the money but I can’t even get support
07-24-2023 12:19 PM
@Rict- Then you won't be retained as that is not in the cards here. There have been many calls for in-between plans for more than the 1gb but less than the 20gb. The company doesn't seem interested after it removed all their single-digit gb plans.
The limited data is a serious sucking decision they made. And here you are. Likely leaving. They don't seem interested in keeping low usage customers and are only keeping the low-cost plans by regulation.
07-24-2023 12:10 PM - edited 07-24-2023 12:11 PM
@Rict wrote:ATTN: Customer Support / RETENTION: I'm posting here because the initial support chat said to contact Customer Support here. ??? I originally signed with PM because i was able to manage my data addons. I rarely use more than 1 G in a cycle but occasionally run a little over. Prior to July I was able to manage it by by a 1 G addon which would carry over across billing cycles. Now the addon expires after 30 days. If I cant get a plan for under 30.00 with 2-5 G then I will switch back to Rogers
to engage support, you actually need to message them here:
07-24-2023 12:08 PM
06-22-2023 11:36 PM
Signing up this hapoened
06-22-2023 06:34 AM
@Synthetichustle no worry, this is something PM can easily reverse. Open a ticket by message, check the inbox for their reply and work with them
06-22-2023 02:43 AM
No just the signing up and porting of my number and it glitched and charged me 5 times my banks says it’s settled I need to get a hold of public now and I only have the receipt and the purchase I expected except the charge happened literally 5 times all at once same time everything it’s weird especially since the receipt I only got one and then the statement has all 5 separate but exactly the same identical
06-21-2023 09:39 PM
@Synthetichustle did you make a manual renewal payment or you let Pre-Authorized payments to take care of it?
Another thing, did you try to make any plan change earlier?
06-21-2023 08:53 PM
Ty
06-21-2023 08:47 PM
@Synthetichustle Please
Message support directly
