03-22-2023 06:51 PM
03-23-2023 02:40 PM
03-23-2023 10:11 AM - edited 03-23-2023 10:12 AM
Is there wifi in the hospital? Can you try 611 some more. Sometimes I have to try again. You didn't say if you were currently suspended. I don't recall being able to call the toll free number when suspended. Just 611. Can you call any other numbers?
Can you set your phone to 3G-only and try again?
Adding - @AM7
03-23-2023 09:54 AM
Hallo and thank you for your response.
I have already purchased my payment vouchers.
I have been with PM since 2010 and this is how I have always paid my monthly bill.
I am in the hospital (not old or dumb, just VERY FRUSTRATED). so I have very limited access to alternative methods of communication.
My phone is not processing the calls (either by "1.855.4PUBLIC" or "*611") so that I can pay with my payment vouchers. This has not been a problem in the past.
Again, I have been with PM since 2010. It should not be difficult to process a bill payment.
This is ABSURD to me.
03-23-2023 07:55 AM
@AM7 try to call 1.855.4PUBLIC from another phone and it should work that way
If not , you can buy vouchers online at ding.com or recharge.com or muskbird.com (with a fees), the you can load your voucher from My Account. I suggest you do that way if you are still unable to use *611 or 1.855.4PUBLIC
And a workaround in the meantime to make calls and text is to download VoIP app TextNow. They will assign you another 10 digits phone numbers and you can calls using the app
if you really need PM support to look into it, then open ticket using chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-23-2023 07:38 AM
Re: URGENT!! i AM IN A TORONTO HOSPITAL (as a patient) and for the FIRST TIME IN 4 years, I am UNABLE TO PAY MY PHONE. My phone will not allow me to dial the "1-855" number or "*611".
PLEASE can someone respond to me?
I have my Payment Vouchers, but am UNABLE TO PAY.
My cell phone is my life-line to my other doctors.
Thank you.
03-22-2023 06:56 PM
Call 1 855 4PUBLIC and enter your 10 digit phone #. You can then add your voucher. For future reference here's extra info on vouchers....
03-22-2023 06:56 PM
HI @Muzammal
It works for me.
Try wait a minute or two and call again
or you can login My Account and load the voucher there if you remember the login
03-22-2023 06:54 PM - edited 03-22-2023 06:55 PM
@Muzammal Look like there is some issue with PM *611, couple posts complained the problem today
Try calling 1-855-4PUBLIC and see if it works
03-22-2023 06:53 PM - edited 03-22-2023 06:54 PM
Sometimes the Ivr system can glitch like that, just retry your call, others will offer further advice, look for more posts to follow.
03-22-2023 06:53 PM
Sometimes I have to try a few times.
03-22-2023 06:53 PM
I just dialed 611 and seems to be working here ok. Give it awhile and re-try.
