02-09-2023 06:09 PM
02-09-2023 06:47 PM
most retailers like Walmart or McD's have free wifi. I usually log in using their free wifi, then buy the desired 15 Day US Roaming add-on.
Make certain you have Roaming enabled in your phone settings. Manually select T-Mobile as your preferred network...others like AT&T or Verizon simply don't work with your PM. There is no roaming talk in Alaska, perhaps other states too.
Be aware that talk in US is going to be ok in some larger cities but will quickly diminish as you move away from city.
Text and data shouldn't be a problem though.
Remember..the add-on only lasts for 15 days or 360 hours. If you have to re-buy...wait until 360 hours + 24 hours has elapsed.
02-09-2023 06:21 PM
Log in to your account and purchase add-on you need.
02-09-2023 06:12 PM
@Bevejan you have trouble login My Account? You can usethe Reset Password link there or open ticket with PM support:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
02-09-2023 06:12 PM - edited 02-09-2023 06:15 PM
@Bevejan If you never created account before because you signed up in store you will need support help to creat one and add on roaming
Watch for reply top of page to the
Right ( envelope image )
02-09-2023 06:12 PM
02-09-2023 06:11 PM
@Bevejan you can dial *611 from your phone and use the menu to buy
Or you can login to My Account and go to Plan and Addon page to buy addons
02-09-2023 06:11 PM
Hi @Bevejan
Login to your account go to Add-ons and of there you choose which one you like to buy it,
or by call *611 if you know your 4 digit PIN.
02-09-2023 06:10 PM - edited 02-09-2023 06:11 PM
@Bevejan Yes just sign into self serve go to plan add on tab and select roaming option you want .. and reboot phone .. also make sure to connect to T mobile
02-09-2023 06:10 PM
Ho do I login my account
