07-07-2026 01:38 PM
Can't receive SMS abroad, want to port my number! How to do that?
07-07-2026 02:08 PM
sorry @mtaktash you can't.
you can message PM and see if they can do anything to help.
you can submit ticket by direct message:
07-07-2026 01:57 PM
is it possible to use a second number saved in my account to port my number?
07-07-2026 01:50 PM
hi @mtaktash
sorry, if you cannot get the text, you cannot port out the number
a workaround is to ask a friend to buy a PM sim card in Canada. change the sim card number to the new one and have your friend to help to receive the porting authorization text and reply Yes for you
