02-03-2025
03:13 PM
02-03-2025
08:17 PM
computergeek541
02-03-2025 03:31 PM
hey. I just reloaded the app and now the plan is showing as correct. Thanks everyone for your help
02-03-2025 03:23 PM
Sometimes it takes a bit for the change to update. If you can, log in to your account using a private/incognito browser, to make sure there are no cache/cookies issues. If that still shows you are on the old plan and the change didnt take place, then i suggest reaching out to a PM Customer service agent, you can message them here:
02-03-2025 03:19 PM
@Johnsssss try going into your app and where it shows your current data usage drag down on the screen until the data refreshes to today's date, then go into the Manage Subscription section to see if it's been updated. The other place you can check is the payment history to see if $35 plus tax has been charged. The app is known to have cacheing issues from time to time which is why you want to force the refresh. If this still does not help reach out to a support agent to let them know
