Unable to Complete Activation
KStark1
Set up an Account for my Son.  Plan selected, paid for and SIM installed.  Downloaded PM App on his phone.  When try to finalize process, App only directs me to select a plan.  How do I bypass this and input the phone number we wish to retain?
@KStark1
Did you use a different email address for your son’s account. You can’t use the same one as your account email.
AK32
Hey there, i believe when i signed up i used the app and followed the steps to select plan, etc.  How did you sign up? web browser?
Keep in mind the emails must be the same (the one used when your son signed up & the one he uses to log in to the app), as PM only supports one plan per account.
If you can log into your sons account, and it says you have an active plan, but cannot use the plan on his phone, i suggest reaching out to a PM Customer service agent here:
eddieO
@KStark1 try going into your phones settings, go to apps and then clear cache/data for the Public Mobile app. Then try logging back in to the app to see if it will allow you to complete activation. If still no luck contact a support agent for assistance
