09-06-2023 01:29 PM
09-06-2023 02:25 PM
first one didn't work, probably due to reception, as I was on the island where closer to US boarder. Then I bought second one needed data at the moment, but work intermittently then stopped working. No data limit set on my phone.
09-06-2023 02:23 PM
Thanks. I bought a second add-on, assumed the first one ran out, but it seems it was out of reception, hence the second one never got used. Yes its been 30 days, last day today, I brought this us since I have some time to see if anything PM could do. It would be a shame that data gets wasted. Used to not have a time limit (not long ago).
09-06-2023 02:20 PM
no, it was the normal add-on. Didn't work because of reception I suspect, as I was on Vancouver Island.
09-06-2023 02:19 PM
Thanks, I've upgraded my data plan. Yes it was bought 30 days ago, the first plan didn't work I suspect due to signal reception as I was on Vancouver Island. I thought my first add on ran out, then bought another one, work for a few min, then stopped working. Used 0 GB. Thats a shame if can't refund it.
09-06-2023 02:09 PM
hi @insitepm1
why would the first one you got didn't work?
did you reboot your phone?
did you check if you have a monthly data limit set on your phone?
09-06-2023 01:52 PM
I doubt if you'll get refunded for unused data add-ons. They now expire 30 days after successfully purchased. If you didn't use 'em, you lose 'em. If neither add-on worked, perhaps you bought the wrong ones.
Don't mean to sound harsh, but plan your data add-on purchase strategically. If you still have regular plan data...that gets used BEFORE add-on data gets used. You can certainly ask for credit for add-on...but I wouldn't be surprised if your request is denied.
Log in on a laptop and click the spinner to see current plan data and Add-on available to you.
09-06-2023 01:49 PM
Did you maybe buy US roaming add-ons? They won't work here.
09-06-2023 01:31 PM - edited 09-06-2023 01:33 PM
@insitepm1 Try to reboot the phone first and try again
Adding you have to be out of plan data before it will get used also
09-06-2023 01:31 PM
Hi @insitepm1
If you just purchased them they can't be expiring. They expire in 30 days of purchase. And if you did purchase them almost 30 days ago and are now bringing this up, you will not be refunded. Just my opinion.
