Re: CS agents
Russ_89
Hi, I bought a sim for my mom during her stay with me in Canada in summer and now she has left the country. Now I’m trying to cancel her plan but when I log into the account using email and password I get a message that says I need to enter a number sent to the phone. However I don’t have access to the sim anymore. Since then i have been charged every month and haven’t been able to cancel the plan. Would you please be able to assist with that?
***Message edited by CS_Agent to comply with the Community terms of service.
2 REPLIES 2
HI @Russ_89
try click Didn't Receive code or Resend code and check if Send email is an option
if same, you will need to have PM support agent to sort it out or cancel the account for you.   You can submit  ticket by direct message:
slusagm
you need to check with PM and they can remove the card from the account
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
