Re: Can't activate subscription or submit a ticket
AThea
Hi! I'm having the same issue. Did they reply to you already?
1 REPLY 1
hi @AThea
there are agents working today, so, they will reply.
For your activation problem, did you try reboot the phone then use PM app again and maybe it can complete the activation that way
if same, you will have to ask PM agent to help.  You can submit  ticket by direct message:
