06-27-2021 02:05 PM - edited 01-06-2022 02:38 AM
Hello,
I added a $15 add-on to make phone calls to U.K, but everytime I try to call it says I have no minutes for it and I haven't even used it yet. Any advice would be helpful, I have made this payment so want to use it.
Thanks,
Avneet
06-27-2021 03:12 PM - edited 06-27-2021 03:13 PM
@avneettakhar wrote:I just did the second step as suggested! Shows funds taken from my account? To reboot my phone, do you mean just turn on/ off?
This is meant as troubleshooting procedure, but rebooting your phone usually isn't necessary for the purposes of getting an add-on to work.
06-27-2021 02:32 PM
06-27-2021 02:27 PM
Thank you, it's now working!
06-27-2021 02:27 PM
Thank you for all the help! I'm ready to go!
06-27-2021 02:24 PM
You have to add the money first then buy the add on. Like a vending machine....add the coins, choose your item, press submit and take your item.
06-27-2021 02:24 PM - edited 06-27-2021 02:27 PM
i think your Purchase Add-Ons not going through,
more info for Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
- Click on ‘Purchase Add-Ons’ on the Overview tab and scroll down to the Add-On calculator.
- Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
- When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
- You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
- If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
- Select ‘Confirm my purchase’, and you’re off to the races!
and do rebooting your phone,
what is mean for Rebooting the phone means to turn off your phone and turn it back on
06-27-2021 02:23 PM - edited 06-27-2021 02:24 PM
Yes, or rather off/on...
06-27-2021 02:22 PM
06-27-2021 02:20 PM
@avneettakhar wrote:I did already make payment with my CC for the U.K add on at $15 as one-time payment, so not sure why it's still not working, but will see about trying your method. I contacted Public Mobile email too ,to ask about issue.
@avneettakhar Looks like you didn't do the second step of purchasing and just added funds. Reboot the phone after making the purchase and you should be set.
06-27-2021 02:19 PM
@avneettakhar : It's a non-intuitive two steps as mentioned. It seems like one selects and pays for it but all you've done is added money. Now you need to use those funds to actually buy the add-on.
06-27-2021 02:18 PM
Since you have $15 available funds, it seems that your credit card has been debited but the add-on hasn't been added yet to your account. When you click on "view payment history", can you see the $15 add-on debited?
06-27-2021 02:16 PM
06-27-2021 02:13 PM
Purchasing add-ons is a two step process. You need to add it and then make a payment.
- Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
06-27-2021 02:12 PM - edited 06-27-2021 02:15 PM
@avneettakhar Try rebooting your phone.
Edit: So the available funds you have showing of $15 in your account are additional funds and not the funds you added to buy the add-on? Purchasing add-ons is a two step process, first add funds and then go back and buy the add-on.
06-27-2021 02:11 PM
Yes, I tried the +44 and it shows as add on in my account.
06-27-2021 02:09 PM - edited 06-27-2021 02:15 PM
Did you just add the add-on? Have you put +44 before the number?
In your self-serve account, can you see you add-on under "My Data & Add-ons"?
