06-02-2025 07:36 PM
I've subscribed 1000 International minutes already,but still can not make calls to China
Does anyone know what's causing this?
06-04-2025 06:12 AM
You can still call China in US if you have US roaming or if you have a Canada/US plan
06-03-2025 10:42 PM
may be due to I am in US rather than Canada😅
06-03-2025 12:29 AM
the currently offered $35 Canada / Mex / us plan included 1000 International calling minutes to several countries including calls to China. As long as the op has this plan, they should be able to call China...just need to have the correct dialing protocol. Hopefully op will come back and report their success.
06-02-2025 10:22 PM
add +86 before the number when you dialing, for example +8610086
06-02-2025 08:07 PM - edited 06-02-2025 08:10 PM
Are you sure you can call China with your 1000-int min?
China is included in Holiday bonuses, though, as I am am aware....
You actually bought Wrong add-on. You should get this one:
06-02-2025 08:02 PM - edited 06-02-2025 08:07 PM
Which add-on did you purchase? Or which plan do you have?
You checked the Usage Breakdown on the main page that the minutes are still there? Your Account is active?
Also, you must be IN Canada to call to China.
If yes, restart your phone and try again. Sometimes a simple restart is all you need.
06-02-2025 07:48 PM - edited 06-02-2025 07:49 PM
I've never had to call China but here's some help courtesy of gogle...
