04-24-2023 12:05 PM - last edited on 04-24-2023 04:28 PM by computergeek541
I need to talk to a moderator as I had a double billing. My plan renewed on April 02 2023 and another on on April 17 2024. April 17th is my proper billing date.
04-24-2023 12:44 PM
HI@Devcon the April 02, how much was it?
you sure you didn't buy addon?
check the payment page first
if you need PM agent help, submit a ticket at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
04-24-2023 12:14 PM
@Devcon Keep in mind PM billing is every 30 days so the date will not be the exact same date every month. If you have questions about double bill though check with the CS Agent.
You can contact an agent using the chatbot. Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a help article about how to contact the CS Agent.
